Ana içeriğe geç
DualShock 3 Front Shell Cover Replacement
Neye ihtiyacın var
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: adım 1, 2 resimden 1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: adım 1, 2 resimden 2.
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
    FixBot'a Sor
    Yorum Ekle
  2. DualShock 3 Front Shell Cover Replacement: adım 2, 3 resimden 1. DualShock 3 Front Shell Cover Replacement: adım 2, 3 resimden 2. DualShock 3 Front Shell Cover Replacement: adım 2, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
    FixBot'a Sor
    Yorum Ekle
  3. DualShock 3 Front Shell Cover Replacement: adım 3, 2 resimden 1. DualShock 3 Front Shell Cover Replacement: adım 3, 2 resimden 2.
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
    FixBot'a Sor
    Yorum Ekle
  4. DualShock 3 Front Shell Cover Replacement: adım 4, 1 resimden 1.
    • Lift the rear cover off of the controller to expose the interior.
    FixBot'a Sor
    Yorum Ekle
  5. DualShock 3 Front Shell Cover Replacement: adım 5, 3 resimden 1. DualShock 3 Front Shell Cover Replacement: adım 5, 3 resimden 2. DualShock 3 Front Shell Cover Replacement: adım 5, 3 resimden 3.
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
    FixBot'a Sor
    Yorum Ekle
  6. DualShock 3 Front Shell Cover Replacement: adım 6, 3 resimden 1. DualShock 3 Front Shell Cover Replacement: adım 6, 3 resimden 2. DualShock 3 Front Shell Cover Replacement: adım 6, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
    FixBot'a Sor
    Yorum Ekle
  7. DualShock 3 Front Shell Cover Replacement: adım 7, 2 resimden 1. DualShock 3 Front Shell Cover Replacement: adım 7, 2 resimden 2.
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
    FixBot'a Sor
    Yorum Ekle
  8. DualShock 3 Front Shell Cover Replacement: adım 8, 1 resimden 1.
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joseph Wambui
253 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team 1-28, O'Regan Fall 2021 York University, Team 1-28, O'Regan Fall 2021 üyesi
YORK-O'REGAN-F21S1G28
1 Üye
3 adet Kılavuz yazıldı
1Rehber Yorum
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 47
Son 30 gün: 243
Her zaman: 7,861
