Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to replace or clean the analog sticks on the Dualshock 4 controller.
  1. Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Do not forcefully loosen the screws, as it will amount to permanent damage of the threads, making removal impossible.
  2. Beginning with the left handle: Pinch the left handle of the controller to introduce an opening. Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on the plier to crack open the casing.
    • Repeat these steps for the right handle.
  3. Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons: Share button Options button
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
  4. Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers. Note the orientation of the cable and make sure it faces the right way when you reconnect it. After the two halves are separated, place the top of the controller off to the side.
    • Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
    • Note the orientation of the cable and make sure it faces the right way when you reconnect it.
    • After the two halves are separated, place the top of the controller off to the side.
  5. Using the blunt forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug. After removal of the plug from the motherboard, the battery can be lifted off of the controller. Hasty removal of the battery plug could warp the plastic grips of the plug.
    • Using the blunt forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug.
    • After removal of the plug from the motherboard, the battery can be lifted off of the controller.
    • Hasty removal of the battery plug could warp the plastic grips of the plug.
  6. Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
  7. Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up. Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
    • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
  8. Carefully dislodge the motherboard assembly from the front cover. Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • Carefully dislodge the motherboard assembly from the front cover.
    • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  9. Successful disassembly of the controller will result in the following three parts, respectively: Motherboard Assembly Front Cover
    • Successful disassembly of the controller will result in the following three parts, respectively:
    • Motherboard Assembly
    • Front Cover
    • Rear Cover
  10. Pull the analog stick covers straight off the joystick posts attached to the motherboard with your fingers. Pull the analog stick covers straight off the joystick posts attached to the motherboard with your fingers.
    • Pull the analog stick covers straight off the joystick posts attached to the motherboard with your fingers.
Sonuç
102 farklı kişi bu kılavuzu tamamladı.
Maaz Hussaini
4.832 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-21, Maness Winter 2014 Cal Poly, Team 6-21, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G21
4 Üyeler
45 adet Kılavuz yazıldı
13 Yorum
So I followed all the steps, got the sticks in. But when I put the controller back together it Wouldent turn on. Do you guys have any clue as to what it could be?
blscott2270 - Yanıt
Same exact thing happened to me, just wouldn't turn back on
Andrew Purcell -
Me too and all the reconnected cables are connected correctly, but it just won’t work.
Andy Hui -
Hope you guys still keep the parts, since the problem can be resolved by following the post below successfully. :)
https://www.google.com.hk/amp/s/amp.redd...
Andy Hui -
i think you didn't put a wire in
Gabrys Holcman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 113
Son 30 gün: 675
Her zaman: 117,333
