Ana içeriğe geç
DualShock 4 CHU-ZCT2U Battery Case Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: adım 1, 3 resimden 1. DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: adım 1, 3 resimden 2. DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 2, 3 resimden 1. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 2, 3 resimden 2. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 2, 3 resimden 3.
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: adım 3, 3 resimden 1. DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: adım 3, 3 resimden 2. DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: adım 3, 3 resimden 3.
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
  4. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 4, 2 resimden 1. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 4, 2 resimden 2.
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
  5. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 5, 3 resimden 1. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 5, 3 resimden 2. DualShock 4 CHU-ZCT2U Battery Case Replacement: adım 5, 3 resimden 3.
    • Unhook the battery case from the motherboard, and pull it off.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Michelle Joseph
1.762 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G5
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 12,310
