Ana içeriğe geç
DualShock 4 CHU-ZCT2U Buttons Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: adım 1, 3 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: adım 1, 3 resimden 2. DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 2, 3 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 2, 3 resimden 2. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 2, 3 resimden 3.
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: adım 3, 3 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: adım 3, 3 resimden 2. DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: adım 3, 3 resimden 3.
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
  4. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 4, 2 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
  5. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 5, 3 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 5, 3 resimden 2. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 5, 3 resimden 3.
    • Unhook the battery case from the motherboard, and pull it off.
  6. DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: adım 6, 3 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: adım 6, 3 resimden 2. DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: adım 6, 3 resimden 3.
    • Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
  7. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 7, 3 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 7, 3 resimden 2. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 7, 3 resimden 3.
    • Remove the rubber pads that secure the buttons in place for the arrow buttons, shape buttons, and Playstation Home button.
    • Do not turn the front shell cover upside down after completing this step, because some of the buttons may fall out.
  8. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 8, 2 resimden 1. DualShock 4 CHU-ZCT2U Buttons Replacement: adım 8, 2 resimden 2.
    • Remove the old buttons, and replace them with new ones using a pair of tweezers.
Sonuç
41 farklı kişi bu kılavuzu tamamladı.
Michelle Joseph
1.762 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G5
3 Üyeler
22 adet Kılavuz yazıldı
2 Yorum
Where can I buy cuh zct2e spares from please
Paramdeep Dhaliwal - Yanıt
Can’t see an updated guide, and this one worked perfectly fine. Used to replace the buttons on a knock-off DualShock 4 from AliExpress. Construction was largely the same, only devoid of a screw anchoring the battery cradle. Would argue this was an extremely easy repair!
Casey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 54
Son 30 gün: 333
Her zaman: 28,075
