Neye ihtiyacın var
Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
Pry the two halves of the shell apart using a plastic opening tool.
Unplug the black and red wires from the power port located on the motherboard.
Remove the old battery from the controller.
Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
45 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Where can I buy cuh zct2e spares from please
