Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The Charging Assembly tends to lose energy and stops working from overheating. This will cause the LED or USB charging port to no longer work. Use this guide to replace the Charging Assembly.
  1. Remove the 4 screws (6.0 mm), which is on the back of the controller, using Phillips #00 screwdriver Place the removed screws to the side. Place the removed screws to the side.
    • Remove the 4 screws (6.0 mm), which is on the back of the controller, using Phillips #00 screwdriver
    • Place the removed screws to the side.
  2. Detach the top frame from the bottom frame by carefully pulling them apart. Detach the top frame from the bottom frame by carefully pulling them apart. Detach the top frame from the bottom frame by carefully pulling them apart.
    • Detach the top frame from the bottom frame by carefully pulling them apart.
  3. Carefully remove the white ribbon connector that is connected to both frames from the top side ( the side where the battery is). Carefully remove the white ribbon connector that is connected to both frames from the top side ( the side where the battery is).
    • Carefully remove the white ribbon connector that is connected to both frames from the top side ( the side where the battery is).
  4. Manta Tornavida Seti
    112 bits for every fix.
    Upgrade Your Toolbox
  5. Take the bottom part (the side without the battery). Remove the white plastic cover which is on the top of the Charging assembly. Remove the white plastic cover which is on the top of the Charging assembly.
    • Take the bottom part (the side without the battery).
    • Remove the white plastic cover which is on the top of the Charging assembly.
  6. Remove the plastic cover which is in front of  the Charging assembly. Remove the transparent plastic cover which is on top of the Charging assembly. Be careful while removing all plastic covers since they are very delicate and can break if removed forcefully.
    • Remove the plastic cover which is in front of the Charging assembly.
    • Remove the transparent plastic cover which is on top of the Charging assembly.
    • Be careful while removing all plastic covers since they are very delicate and can break if removed forcefully.
  7. Remove the two screw (4.00 mm) using the #00 Phillips screwdriver, which is holding the Charging assembly and the frame together. Remove the double-sided tape, with the plastic opening tool, that is keeping the chip attached to the frame. Take out the charging assembly chip.
    • Remove the two screw (4.00 mm) using the #00 Phillips screwdriver, which is holding the Charging assembly and the frame together.
    • Remove the double-sided tape, with the plastic opening tool, that is keeping the chip attached to the frame.
    • Take out the charging assembly chip.
  8. Remove the white ribbon cable from the charging assembly chip. Replace the Charging assembly chip with a new one. Replace the Charging assembly chip with a new one.
    • Remove the white ribbon cable from the charging assembly chip.
    • Replace the Charging assembly chip with a new one.
Sonuç
If you have followed all the steps correctly, your LED Light should light up once you reassemble and plug your device to a USB cord. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 217
Her zaman: 1,813
