Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the 4 screws (6.0 mm), which is on the back of the controller, using Phillips #00 screwdriver
Place the removed screws to the side.
Detach the top frame from the bottom frame by carefully pulling them apart.
Carefully remove the white ribbon connector that is connected to both frames from the top side ( the side where the battery is).
Take the bottom part (the side without the battery).
Remove the white plastic cover which is on the top of the Charging assembly.
Remove the plastic cover which is in front of the Charging assembly.
Remove the transparent plastic cover which is on top of the Charging assembly.
Remove the two screw (4.00 mm) using the #00 Phillips screwdriver, which is holding the Charging assembly and the frame together.
Remove the double-sided tape, with the plastic opening tool, that is keeping the chip attached to the frame.
Take out the charging assembly chip.
Remove the white ribbon cable from the charging assembly chip.
3 farklı kişi bu kılavuzu tamamladı.
