Ana içeriğe geç
DualShock 4 CHU-ZCT2U Disassembly
Neye ihtiyacın var
  1. DualShock 4 CHU-ZCT2U Disassembly, First Screws: adım 1, 2 resimden 1. DualShock 4 CHU-ZCT2U Disassembly, First Screws: adım 1, 2 resimden 2.
    • All the screws are the same in the controller (Phillips's head).
  2. DualShock 4 CHU-ZCT2U Disassembly, Opening the Case: adım 2, 1 resimden 1.
    • Use a plastic spudger to open the case. Try not to scratch the plastic.
  3. DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: adım 3, 2 resimden 1. DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: adım 3, 2 resimden 2.
    • Be careful opening the case because there is a ribbon cable holding the 3 halves together.
    • The plastic for the lightbar will look different from mine because it's fragile and it broke.
  4. DualShock 4 CHU-ZCT2U Disassembly, Battery: adım 4, 2 resimden 1. DualShock 4 CHU-ZCT2U Disassembly, Battery: adım 4, 2 resimden 2.
    • Remove the battery and the screw underneath it.
  5. DualShock 4 CHU-ZCT2U Disassembly, Touchpad Ribbon Cable: adım 5, 1 resimden 1.
    • The ribbon cable slots through the rectangular hole in the plastic beneath.
  6. DualShock 4 CHU-ZCT2U Disassembly, Board: adım 6, 1 resimden 1.
    • Remove the board.
  7. DualShock 4 CHU-ZCT2U Disassembly, You Are Done!: adım 7, 1 resimden 1.
    • You're finished with your DualShock 4 dissasembly!
Sonuç
To reassemble your device, follow these instructions in reverse order. If there are any issues, please tell me as this is my first guide
8 farklı kişi bu kılavuzu tamamladı.
Mintyboi 88
316 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 72
Son 30 gün: 392
Her zaman: 12,783
