Ana içeriğe geç
DualShock 4 CHU-ZCT2U Outer Shell Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. DualShock 4 CHU-ZCT2U Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 1. DualShock 4 CHU-ZCT2U Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 2. DualShock 4 CHU-ZCT2U Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Outer Shell Replacement: adım 2, 3 resimden 1. DualShock 4 CHU-ZCT2U Outer Shell Replacement: adım 2, 3 resimden 2. DualShock 4 CHU-ZCT2U Outer Shell Replacement: adım 2, 3 resimden 3.
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
David Seale
1.630 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G5
3 Üyeler
22 adet Kılavuz yazıldı
Bir Yorum
FYI for anyone looking: re-shelling a v1 controller with v2 innards is possible but incredibly time consuming. My 20th anniversary controller died (v3 circuit board) so I transplanted all parts from a PS-Pro controller. It requires lots of cutting and trimming of the shell to match the inner profile of the newer shell to enable it to close up cleanly. There are no cuts or modifications needed to the V2 controller components however, but the new style light bar need migrating across.
Steve - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 12
Her zaman: 5,568
