Ana içeriğe geç
DualShock 4 CUH-ZCT1 Charging Port Replacement
Neye ihtiyacın var
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: adım 1, 1 resimden 1.
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 2, 1 resimden 1.
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 3, 2 resimden 1. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 3, 2 resimden 2.
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 4, 1 resimden 1.
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 5, 1 resimden 1.
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 6, 1 resimden 1.
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 7, 2 resimden 1. DualShock 4 CUH-ZCT1 Charging Port Replacement: adım 7, 2 resimden 2.
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Andy Lam
307 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team P-10, Allen Fall 2022 York University, Team P-10, Allen Fall 2022 üyesi
YORK-ALLEN-F22SPG10
1 Üye
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 71
Son 30 gün: 272
Her zaman: 3,207
