Ana içeriğe geç
DualShock 4 Controller Rumble Motors Replacement
Neye ihtiyacın var
  1. DualShock 4 Controller Rumble Motors Replacement, Rumble Motors: adım 1, 1 resimden 1.
    • Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
  2. DualShock 4 Controller Rumble Motors Replacement: adım 2, 1 resimden 1.
    • Remove the rear plate.
    • We recommend using a metal spudger for this step.
  3. DualShock 4 Controller Rumble Motors Replacement: adım 3, 2 resimden 1. DualShock 4 Controller Rumble Motors Replacement: adım 3, 2 resimden 2.
    • Desolder the joints that attach the rumble motors to the motherboard.
    • For more information on soldering, click here.
  4. DualShock 4 Controller Rumble Motors Replacement: adım 4, 2 resimden 1. DualShock 4 Controller Rumble Motors Replacement: adım 4, 2 resimden 2.
    • There is a hidden screw underneath the battery pack that attaches the faceplate to the motherboard.
    • Lift the pack and remove the 10mm screw using the #000 Phillips screwdriver.
  5. DualShock 4 Controller Rumble Motors Replacement: adım 5, 1 resimden 1.
    • Remove the faceplate from the motherboard.
  6. DualShock 4 Controller Rumble Motors Replacement: adım 6, 3 resimden 1. DualShock 4 Controller Rumble Motors Replacement: adım 6, 3 resimden 2. DualShock 4 Controller Rumble Motors Replacement: adım 6, 3 resimden 3.
    • With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I’d recommend adding removal instructions for the touchpad also
AlexMorse - Yanıt
the rumble packs are stuck with an adhesive on my controller. The best way to remove the rumble pack in this case? thanks
Ka Erd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 69
Son 30 gün: 249
Her zaman: 30,196
