Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
DualShock 4 Right Analog Stick Replacement
Neye ihtiyacın var
  1. DualShock 4 Right Analog Stick Replacement, Controller: adım 1, 1 resimden 1.
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
  2. DualShock 4 Right Analog Stick Replacement: adım 2, 3 resimden 1. DualShock 4 Right Analog Stick Replacement: adım 2, 3 resimden 2. DualShock 4 Right Analog Stick Replacement: adım 2, 3 resimden 3.
    • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on tool to pry open the casing.
    • Repeat these steps for the right handle.
  3. DualShock 4 Right Analog Stick Replacement: adım 3, 3 resimden 1. DualShock 4 Right Analog Stick Replacement: adım 3, 3 resimden 2. DualShock 4 Right Analog Stick Replacement: adım 3, 3 resimden 3.
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
  4. DualShock 4 Right Analog Stick Replacement, Disconnect the battery: adım 4, 2 resimden 1. DualShock 4 Right Analog Stick Replacement, Disconnect the battery: adım 4, 2 resimden 2.
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  5. DualShock 4 Right Analog Stick Replacement, Remove the battery: adım 5, 1 resimden 1.
    • Remove the battery.
  6. DualShock 4 Right Analog Stick Replacement, Disassembling DualShock 4 Motherboard Assembly: adım 6, 1 resimden 1.
    • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
  7. DualShock 4 Right Analog Stick Replacement: adım 7, 2 resimden 1. DualShock 4 Right Analog Stick Replacement: adım 7, 2 resimden 2.
    • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
  8. DualShock 4 Right Analog Stick Replacement: adım 8, 2 resimden 1. DualShock 4 Right Analog Stick Replacement: adım 8, 2 resimden 2.
    • Carefully dislodge the motherboard assembly from the front cover.
    • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  9. DualShock 4 Right Analog Stick Replacement, Disassembly Complete: adım 9, 3 resimden 1. DualShock 4 Right Analog Stick Replacement, Disassembly Complete: adım 9, 3 resimden 2. DualShock 4 Right Analog Stick Replacement, Disassembly Complete: adım 9, 3 resimden 3.
    • Successful disassembly of the controller will result in the following three parts, respectively:
    • Motherboard Assembly
    • Front Cover
    • Rear Cover
  10. DualShock 4 Right Analog Stick Replacement, Right Analog Stick: adım 10, 3 resimden 1. DualShock 4 Right Analog Stick Replacement, Right Analog Stick: adım 10, 3 resimden 2. DualShock 4 Right Analog Stick Replacement, Right Analog Stick: adım 10, 3 resimden 3.
    • These are the solder connections that will need to be desoldered. Since the board is upside down, left will become right.
    • Use a desoldering wick and flux to melt and remove the solder
    • This may take a bit of practice since all the solder will have to be removed. It does help to pull a bit on the joystick while melting the solder and using the wick.
  11. DualShock 4 Right Analog Stick Replacement: adım 11, 3 resimden 1. DualShock 4 Right Analog Stick Replacement: adım 11, 3 resimden 2. DualShock 4 Right Analog Stick Replacement: adım 11, 3 resimden 3.
    • Once all the contacts are desoldered, the old joystick can be removed.
    • Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes.
    • Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
  12. DualShock 4 Right Analog Stick Replacement: adım 12, 3 resimden 1. DualShock 4 Right Analog Stick Replacement: adım 12, 3 resimden 2. DualShock 4 Right Analog Stick Replacement: adım 12, 3 resimden 3.
    • Double check to make sure the joystick is seated properly.
    • Solder all the contacts to the board.
    • Here is the board after the repair. All that is left is to clean off the old flux with some isopropyl alcohol.
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
oldturkey03
780.979 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
32 Üyeler
530 adet Kılavuz yazıldı
14 Yorum
I just tried to remove both joystick and replaced them but unfortunately only one joystick works and that one that works it's stuck on and only moves in one direction.
Juan Hernandez - Yanıt
I've not been able to actually get the solder out, would love any suggestions or tips.
James Napoli - Yanıt
send me a couple of pictures on what your repair looks like thus far. Send them to my email. Click on my username and my email address is on my profile. Let's see what you got so far.
oldturkey03 -
This is a very difficult repair, what this guy didn't mention is you need a very expensive solder station with an electric solder sucker. The solder needs removing and it's nearly impossible without damaging the tracking.
Dave bolton - Yanıt
You definitely need some soldering experience but the repairability is not that difficult. The soldering points are big enough for any cheap ($40) soldering iron can get too. As for removing them, it helps to use flux and also a soldering wick to absorb all the old solder. It is not easy but not the most difficult repair. P.S you do not need the expensive soldering stating with hot air etcetera. This works perfectly as it get hot beyond the required point to melt the solder
Eyob Grainge -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 58
Son 7 gün: 388
Son 30 gün: 1,990
Her zaman: 153,476
