Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to remove a defective touchpad on a Dualshock 4 controller.
  1. Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Do not forcefully loosen the screws, as it will amount to permanent damage of the threads, making removal impossible.
  2. Beginning with the left handle: Pinch the left handle of the controller to introduce an opening. Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on the plier to crack open the casing.
    • Repeat these steps for the right handle.
  3. Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons: Share button Options button
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
  4. Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers. Note the orientation of the cable and make sure it faces the right way when you reconnect it. After the two halves are separated, place the top of the controller off to the side.
    • Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
    • Note the orientation of the cable and make sure it faces the right way when you reconnect it.
    • After the two halves are separated, place the top of the controller off to the side.
  5. Using the blunt forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug. After removal of the plug from the motherboard, the battery can be lifted off of the controller. Hasty removal of the battery plug could warp the plastic grips of the plug.
    • Using the blunt forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug.
    • After removal of the plug from the motherboard, the battery can be lifted off of the controller.
    • Hasty removal of the battery plug could warp the plastic grips of the plug.
  6. Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
  7. Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up. Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
    • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
  8. Carefully dislodge the motherboard assembly from the front cover. Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • Carefully dislodge the motherboard assembly from the front cover.
    • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  9. Successful disassembly of the controller will result in the following three parts, respectively: Motherboard Assembly Front Cover
    • Successful disassembly of the controller will result in the following three parts, respectively:
    • Motherboard Assembly
    • Front Cover
    • Rear Cover
  10. After the motherboard is set aside, lay the front panel on the ground.
    • After the motherboard is set aside, lay the front panel on the ground.
    • You can now see the touch pad which is outlined on the top and bottom by an orange line.
  11. Now pick the front panel up, and use one hand to press the touch pad up from the front of the panel. There are no other restrictions attached to the touch pad. It should slide right out and back in without any effort. There are no other restrictions attached to the touch pad. It should slide right out and back in without any effort.
    • Now pick the front panel up, and use one hand to press the touch pad up from the front of the panel.
    • There are no other restrictions attached to the touch pad. It should slide right out and back in without any effort.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Mark
6.430 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-21, Maness Winter 2014 Cal Poly, Team 6-21, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G21
4 Üyeler
45 adet Kılavuz yazıldı
5 Yorum
when put back the right side and the bottom doesnt click properly. What am I doing wrong?
Karakan Dement - Yanıt
You ever figure this out?
Ayushmaan Ganotra -
I disassembled my controller and changed the sticks and case now the controller moves on it's own and gets stuck when moving ... How can I fix this or is there something I may have done wrong when I was reassembling it???
tomgunnz45 - Yanıt
So, there are some differences with the new DS4 from 2016. and frustratingly the flip up piece that is used to tighten the ribbon connection for the touch pad is no longer there. I have no idea how to get the ribbon back into it's connector. Any ideas?
Jacob L - Yanıt
when i took the ribbon cable out, the cover when with it now i cant put the cover back so i can put back the cable
Brandon Butanda - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 237
Son 30 gün: 975
Her zaman: 45,449
