Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
This is how the controller looks like. You will first need to flip it over and unscrew the screws.
Then you will get a plastic open tool to push against the lines to make the controller come apart.
Now with the tool you will make the controller come apart again by pushing against the buttons share and options.
Now you will be taking apart the battery from the controller with tweezers from the little white block.
Now that the battery is gone you will be able to see a little screw and you will need to take it apart.
5 farklı kişi bu kılavuzu tamamladı.
