Giriş
CAUTION: AC VOLTAGES. Discharge capacitor before removing, if possible. If not, please leave device unplugged for two to three days before attempting repair. Capacitors can give you a nasty and/or dangerous shock.
Neye ihtiyacın var
Use a small screwdriver to remove the four screws on the rear corners of the case.
Use your hands to gently pry apart the front and rear halves of the case.
Desolder the defective C5 Capacitor (a black, 680uF 20V radial model).
Replace the resistor with a similar value cap, such as a 25V Rubycon.
4 farklı kişi bu kılavuzu tamamladı.
