Ana içeriğe geç
Giriş
Part # INR18650-13P
  1. Durofix RV332 Battery Replacement, Battery: adım 1, 3 resimden 1. Durofix RV332 Battery Replacement, Battery: adım 1, 3 resimden 2. Durofix RV332 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: adım 2, 2 resimden 1. Durofix RV332 Battery Replacement: adım 2, 2 resimden 2.
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: adım 3, 1 resimden 1.
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brennan Wade
107 İtibar
1 Kılavuz yazıldı
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 2,356
