Ana içeriğe geç
Durofix RV332 Motor Replacement
Neye ihtiyacın var
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: adım 1, 1 resimden 1.
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Durofix RV332 Motor Replacement: adım 2, 2 resimden 1. Durofix RV332 Motor Replacement: adım 2, 2 resimden 2.
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. Durofix RV332 Motor Replacement: adım 3, 2 resimden 1. Durofix RV332 Motor Replacement: adım 3, 2 resimden 2.
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  4. Durofix RV332 Motor Replacement: adım 4, 1 resimden 1.
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  5. Durofix RV332 Motor Replacement: adım 5, 3 resimden 1. Durofix RV332 Motor Replacement: adım 5, 3 resimden 2. Durofix RV332 Motor Replacement: adım 5, 3 resimden 3.
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  6. Durofix RV332 Motor Replacement: adım 6, 1 resimden 1.
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
Sonuç
Tyler Vincent
479 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 15
Her zaman: 826
