Giriş
If your charging port has become unresponsive or loose, it may be time for replacement or adjustment. This guide provides step-by-step instructions on how to access and replace the charging port.
Neye ihtiyacın var
Use wire cutters or scissors to cut the wires attached to the charging port, and remove the charging port.
Solder the black wire to the bottom-most node of the new charging port. Solder the red wire to the uppermost node of the new charging port. See the following link for soldering tips: How To Solder and Desolder Connections
Bir başkası bu kılavuzu tamamladı.
