Ana içeriğe geç
Dynex DX-WBRDVD1 Optical Drive Replacement
Neye ihtiyacın var
  1. Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: adım 1, 2 resimden 1. Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: adım 4, 2 resimden 1. Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
  5. Dynex DX-WBRDVD1 Optical Drive Replacement: adım 5, 2 resimden 1. Dynex DX-WBRDVD1 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Detach the tape wires from the motherboard and power board.
  6. Dynex DX-WBRDVD1 Optical Drive Replacement: adım 6, 2 resimden 1. Dynex DX-WBRDVD1 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Lift the disc drive up to a 45 degree angle and pull back out of the device shell
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 387
