Ana içeriğe geç
Dynex DX-WBRDVD1 Power Supply Board Replacement
Neye ihtiyacın var
  1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: adım 1, 2 resimden 1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 2, 1 resimden 1.
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 3, 1 resimden 1.
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: adım 4, 2 resimden 1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: adım 4, 2 resimden 2.
    • Remove the 9-pin white wire from the power board (brown) that connects to the motherboard (green).
  5. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 5, 2 resimden 1. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 5, 2 resimden 2.
    • Remove the front plate of the device by removing the top two screws on either side and pulling the plate away.
    • Make sure to place the grounding wire between the screw and the device when reassembling.
  6. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 6, 2 resimden 1. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 6, 2 resimden 2.
    • Remove the 4 screws holding the power board to the body of the device.
    • Remember to connect a grounding wire to the screw next to the front panel and optical drive when reassembling.
  7. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 7, 2 resimden 1. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 7, 2 resimden 2.
    • Press down on the plastic flap to unlatch the white clip on the edge of the power supply board.
  8. Dynex DX-WBRDVD1 Power Supply Board Replacement: adım 8, 1 resimden 1.
    • Remove the power supply board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 673
