Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This is the guide to crack into your device, almost every repair guide will need this completed first before being able to tear into the hardware below.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
    • Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
  2. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  3. Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
    • Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  4. Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Check that the power cord is not preventing the device from opening or closing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 60
