Ana içeriğe geç
Dynex DX-WBRDVD1 WiFi Antenna Replacement
Neye ihtiyacın var
  1. Dynex DX-WBRDVD1 WiFi Antenna Replacement, Top Cover: adım 1, 2 resimden 1. Dynex DX-WBRDVD1 WiFi Antenna Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 WiFi Antenna Replacement: adım 2, 1 resimden 1.
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 WiFi Antenna Replacement: adım 3, 1 resimden 1.
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: adım 4, 3 resimden 1. Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: adım 4, 3 resimden 2. Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: adım 4, 3 resimden 3.
    • Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
    • Use a pointed tool and press down on the indents on both sides of the clip to loosen.
  5. Dynex DX-WBRDVD1 WiFi Antenna Replacement: adım 5, 1 resimden 1.
    • Remove the two 7mm screws from both sides of the antenna.
  6. Dynex DX-WBRDVD1 WiFi Antenna Replacement: adım 6, 2 resimden 1. Dynex DX-WBRDVD1 WiFi Antenna Replacement: adım 6, 2 resimden 2.
    • Slide the antenna inwards and gently remove.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 260
