Giriş
This guide will take you step by step on how to replace the motherboard of your DX-WEGRTR router. There are multiple reasons why you'd want to do this, including electrical damage due to a power surge, or a simple broken electrical component within it such a capacitor. Refer to the troubleshooting page to see other causes of possible motherboard malfunctioning.
Neye ihtiyacın var
Remove the two Phillips #00 screws in the bottom of the device securing the casing.
Two 7.8 mm Phillips screws
Gently pry the edge of the vessel with a plastic opening tool, the previously used screwdriver, or your hands. Move your tool around all the edges of the router until you get all four of the plastic holders.
Use your handy Phillips screwdriver to unscrew the Phillips #00 screw to the lower left side of the motherboard.
One 4.4 mm Phillips #00 screw.
Carefully slide the plastic housing of the antennas (the back cover of the router) up and out of its slot.
You may need to move the motherboard at this time in order to giggle the antenna's housing off.
Finally, remove the motherboard from its place making sure to not pull the cable connecting the antennas.
Bir başkası bu kılavuzu tamamladı.
