Ana içeriğe geç
Dyson Ball Animal Brushbar Replacement
Neye ihtiyacın var
  1. Dyson Ball Animal Brushbar Replacement, Brushbar: adım 1, 2 resimden 1. Dyson Ball Animal Brushbar Replacement, Brushbar: adım 1, 2 resimden 2.
    • Turn off and unplug the vacuum.
  2. Dyson Ball Animal Brushbar Replacement: adım 2, 2 resimden 1. Dyson Ball Animal Brushbar Replacement: adım 2, 2 resimden 2.
    • Recline the vacuum on its back and position the brushbar up in the air.
  3. Dyson Ball Animal Brushbar Replacement: adım 3, 2 resimden 1. Dyson Ball Animal Brushbar Replacement: adım 3, 2 resimden 2.
    • Pull the red ring around the base of the brush head down and away from the body.
  4. Dyson Ball Animal Brushbar Replacement: adım 4, 1 resimden 1.
    • Pull the brushbar out from the vacuum.
  5. Dyson Ball Animal Brushbar Replacement: adım 5, 1 resimden 1.
    • Pull up the red tabs on the top of the brushbar.
  6. Dyson Ball Animal Brushbar Replacement: adım 6, 1 resimden 1.
    • Remove the front panel of the brushbar.
  7. Dyson Ball Animal Brushbar Replacement: adım 7, 3 resimden 1. Dyson Ball Animal Brushbar Replacement: adım 7, 3 resimden 2. Dyson Ball Animal Brushbar Replacement: adım 7, 3 resimden 3.
    • Remove the four screws with a Torx T10 Screwdriver.
  8. Dyson Ball Animal Brushbar Replacement: adım 8, 2 resimden 1. Dyson Ball Animal Brushbar Replacement: adım 8, 2 resimden 2.
    • Lift the brushbar away from the housing while pulling it out to the side.
    • This may take some force and wiggling.
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Mairead Nye
426 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, Banghart Spring 2017 Cal Poly, Team S15-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G5
4 Üyeler
16 adet Kılavuz yazıldı
15 Yorum
I'm like to know if this works for the Dyson ball animal2 as well
Jean Riehle - Yanıt
It does work
ade 23 -
We used this guide to clean the brushbar assembly of the DC41 animal too. Thank you SO MUCH for writing it!!! We’d never have tried pulling the bar off sideways.
Anthony Clark - Yanıt
Thanks to MaireadNye for the easy to follow guide. I used this to remove and clean the brush bar and its housing on a Dyson Animal 2 upright vacuum. The four screws securing the brush bar were not T10 Torx, but rather Phillips head, so no big deal. What took the longest amount of time was searching for my Torx tools before I began, which is unlike me. I usually grab tools as I go, but since only one was required, I decided to (unnecessarily) have it ready to go. I used vinegar first to get out a soy sauce type smell, but dish soap was what worked. Thanks again!
(And thanks to Dyson for making stuff like this user-friendly!)
renee marie - Yanıt
what is the part and part number of the wheel in between the brush bar?
Jerry Taylor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 137
Son 30 gün: 617
Her zaman: 82,886
