Ana içeriğe geç
Dyson Ball Animal Power Button Replacement
Neye ihtiyacın var
  1. Dyson Ball Animal Power Button Replacement, Power Button: adım 1, 2 resimden 1. Dyson Ball Animal Power Button Replacement, Power Button: adım 1, 2 resimden 2.
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: adım 2, 1 resimden 1.
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: adım 3, 2 resimden 1. Dyson Ball Animal Power Button Replacement: adım 3, 2 resimden 2.
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: adım 4, 2 resimden 1. Dyson Ball Animal Power Button Replacement: adım 4, 2 resimden 2.
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: adım 5, 3 resimden 1. Dyson Ball Animal Power Button Replacement: adım 5, 3 resimden 2. Dyson Ball Animal Power Button Replacement: adım 5, 3 resimden 3.
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: adım 6, 2 resimden 1. Dyson Ball Animal Power Button Replacement: adım 6, 2 resimden 2.
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: adım 7, 2 resimden 1. Dyson Ball Animal Power Button Replacement: adım 7, 2 resimden 2.
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Hank Wai
166 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, Banghart Spring 2017 Cal Poly, Team S15-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G5
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 73
Her zaman: 6,708
