Ana içeriğe geç
Dyson Cinetic Animal Ball Motor Replacement
Neye ihtiyacın var
  1. Dyson Cinetic Animal Ball Motor Replacement, Release the canister: adım 1, 1 resimden 1.
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement, Remove the canister: adım 2, 1 resimden 1.
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the base plate: adım 3, 1 resimden 1.
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: adım 4, 1 resimden 1.
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove the plastic disc.
  5. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the plastic enclosure: adım 5, 1 resimden 1.
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
  6. Dyson Cinetic Animal Ball Motor Replacement, Open up the plastic sphere: adım 6, 1 resimden 1.
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: adım 7, 2 resimden 1. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: adım 7, 2 resimden 2.
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alexandria Pompeii
400 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-5, Banghart Winter 2017 Cal Poly, Team 9-5, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S9G5
3 Üyeler
18 adet Kılavuz yazıldı
4 Yorum
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - Yanıt
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - Yanıt
great instructions, dismantled perfectly.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 53
Son 30 gün: 244
Her zaman: 22,375
