Ana içeriğe geç
Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement
Neye ihtiyacın var
  1. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement, Canister Unlocking Mechanism Spring: adım 1, 1 resimden 1.
    • If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
  2. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: adım 2, 1 resimden 1.
    • Locate the spring in the small opening between the handle and ball of the vacuum body.
  3. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Pull out the spring by carefully inserting tweezers into the opening.
    • Carefully remove the spring.
Sonuç
Allison Turnbaugh
213 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-5, Banghart Winter 2017 Cal Poly, Team 9-5, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S9G5
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 2,431
