Giriş
The Dyson brushbar is located on the underside of the base of the vacuum.
Neye ihtiyacın var
4 farklı kişi bu kılavuzu tamamladı.
3 Yorum
If you look toward the center part on each side of the belt container you'll see 2 little clear tabs sticking out on each of the inner parts of the purple brush. Use a flat head screw driver and gently push each of those tabs in (obviously one side of roller then the other side) as you pull outward on the outer side of the roller (it's a 2 piece roller)
