Ana içeriğe geç
Dyson DC08 brush replacement
Neye ihtiyacın var
  1. Dyson DC08 brush replacement, Brush: adım 1, 3 resimden 1. Dyson DC08 brush replacement, Brush: adım 1, 3 resimden 2. Dyson DC08 brush replacement, Brush: adım 1, 3 resimden 3.
    • Take off the dust cannister.
    • Remove the suction hose.
  2. Dyson DC08 brush replacement: adım 2, 3 resimden 1. Dyson DC08 brush replacement: adım 2, 3 resimden 2. Dyson DC08 brush replacement: adım 2, 3 resimden 3.
    • Extract the front filter.
  3. Dyson DC08 brush replacement: adım 3, 3 resimden 1. Dyson DC08 brush replacement: adım 3, 3 resimden 2. Dyson DC08 brush replacement: adım 3, 3 resimden 3.
    • Extract the rear filter.
    • Unscrew the first Torx screw.
  4. Dyson DC08 brush replacement: adım 4, 2 resimden 1. Dyson DC08 brush replacement: adım 4, 2 resimden 2.
    • Optionally, remove the rear filter cover.
  5. Dyson DC08 brush replacement: adım 5, 2 resimden 1. Dyson DC08 brush replacement: adım 5, 2 resimden 2.
    • Unscrew the 2nd Torx screw.
    • Disassemble the suction hose connection (optional)
  6. Dyson DC08 brush replacement: adım 6, 3 resimden 1. Dyson DC08 brush replacement: adım 6, 3 resimden 2. Dyson DC08 brush replacement: adım 6, 3 resimden 3.
    • Remove the wheels.
    • The wheels clip onto the body of the appliance.
    • Unscrew the 4 Torx screws (two in the right and two on the left).
  7. Dyson DC08 brush replacement: adım 7, 2 resimden 1. Dyson DC08 brush replacement: adım 7, 2 resimden 2.
    • Open the body of the vacuum cleaner.
    • You can use a multimeter to test the switch.
    • Disconnect the brown wire at the switch.
    • Disconnect the blue wire at the single connector by the motor.
    • Lift out the motor.
  8. Dyson DC08 brush replacement: adım 8, 2 resimden 1. Dyson DC08 brush replacement: adım 8, 2 resimden 2.
    • Open the motor housing (4 clips).
    • Remover the motor from its plastic casing.
    • Disconnect the motor.
  9. Dyson DC08 brush replacement: adım 9, 3 resimden 1. Dyson DC08 brush replacement: adım 9, 3 resimden 2. Dyson DC08 brush replacement: adım 9, 3 resimden 3.
    • disassembly of 2 engine coals (1 Phillips screw per coal)
  10. Dyson DC08 brush replacement: adım 10, 3 resimden 1. Dyson DC08 brush replacement: adım 10, 3 resimden 2. Dyson DC08 brush replacement: adım 10, 3 resimden 3.
    • Worn brush.
    • Opening the brush housing.
  11. Dyson DC08 brush replacement: adım 11, 3 resimden 1. Dyson DC08 brush replacement: adım 11, 3 resimden 2. Dyson DC08 brush replacement: adım 11, 3 resimden 3.
    • Extraction of the brush and spring.
  12. Dyson DC08 brush replacement: adım 12, 2 resimden 1. Dyson DC08 brush replacement: adım 12, 2 resimden 2.
    • Removing the brush.
  13. Dyson DC08 brush replacement: adım 13, 2 resimden 1. Dyson DC08 brush replacement: adım 13, 2 resimden 2.
    • Soldering a new brush.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
christophe
806 İtibar
2 adet Kılavuz yazıldı
16Kılavuz Yorumları
Very useful guide - I treated myself to a new motor as the cost was not much more than the cost of replacement brushes.
Bob - Yanıt
Hi, where did you buy the new motor?
Nadja -
Bravo, très bon tutoriel
shog shog - Yanıt
Bonjour
et si on n’a rien pour souder, y a t’il une autre solution svp?
GALLAS - Yanıt
Bonjour ! Si vous ne disposez pas de matérial de soudure, nous vous conseillons de vous rendre à un Repair Café ou un Fab Lab. Ces associations mettent du matériel à disposition et peuvent éventuellement aussi vous conseiller sur la démarche à suivre. Bonne réparation !
Claire Miesch -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 46
Son 30 gün: 177
Her zaman: 20,047
