Ana içeriğe geç
Dyson DC14 Power Cord Replacement
Neye ihtiyacın var
  1. Dyson DC14 Power Cord Replacement, Power Switch: adım 1, 2 resimden 1. Dyson DC14 Power Cord Replacement, Power Switch: adım 1, 2 resimden 2.
    • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
    • Remove the canister from the vacuum.
    • Disconnect the telescopic vacuum wand.
    • Remove the two T15 Torx screws securing the switch cover to the vacuum.
  2. Dyson DC14 Power Cord Replacement: adım 2, 2 resimden 1. Dyson DC14 Power Cord Replacement: adım 2, 2 resimden 2.
    • Push outward on the two plastic clips that secure the switch cover to the vacuum.
    There are also two screws ( one of which can been seen on the photo and another a few inches below ) that need to be removed BEFORE pushing outward on the plastic tabs.
    martyn.lockhart - Yanıt
  3. Dyson DC14 Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the switch cover from the vacuum.
    • The purple switch button may separate from the rest of the switch cover.
  4. Dyson DC14 Power Cord Replacement: adım 4, 1 resimden 1.
    • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
    • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
    • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
    I can’t unplug the old starter. It seems stuck. What am I doing wrong?
    Jane Wells - Yanıt
    I can’t unplug old starter from dyson dc14. Seems stuck. Help please
    Jane Wells - Yanıt
  5. Dyson DC14 Power Cord Replacement, Power Cord: adım 5, 1 resimden 1.
    • Remove the other terminal for the power cord that connects to the terminal below the power switch.
    • Holding them by their connectors, separate the remaining wire of the power cord from the internal power cable.
    Love this repair guid
    Justin DePascale - Yanıt
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Donald Percivalle
1.944 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-22, Amido Fall 2012 Cal Poly, Team 3-22, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G22
4 Üyeler
8 adet Kılavuz yazıldı
5 Yorum
thanks, Just the basic instructions I needed.
debpet666 - Yanıt
What a great site! Easy to follow instructions. My part fit perfectly. I booked marked you site and will be back when necessary. Thank y’all
Jerry Chastine - Yanıt
Definitely helpful
Allen wrench works fine.
No need to buy Torx screwdriver
tacsfs - Yanıt
I was able to remove the terminals from the power cord but am not sure how to remove the connectors from the wires. I am guessing I need to remove these connectors to get the old power cord and then use the connectors with the new wires.
carrikenney - Yanıt
Hello, I have been given a Dyson DC 14 and it looks like the plug has been chopped off clean all the way at the very end of the Court. I would like to replace the plug or the entire cord if that's the case. But I am wondering if I do replace the cord and spend that type of money how do I know if it's going to work or not? So is there a way to test the vacuum with my car battery by touching the two cords to the terminals? also which cord is positive and which cord is negative cuz there's a black and a white cord? I have always wanted a Dyson vacuum. It is actually been a dream of mine because I think they're so cool. So now that I have one I want to fix it as inexpensively as possible. Please help thank you so much Brian Higgins
BRIAN HIGGINS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 65
Her zaman: 57,761
