Giriş
The Dyson DC24 has a common fault where the lower small bearing breaks off the axel and makes the ball loose and not roll properly.
This guide will show you how to replace the lower small bearing.
Neye ihtiyacın var
Recline vacuum all the way to expose as much of the ball as possible.
2 farklı kişi bu kılavuzu tamamladı.
4 Yorum
When replacing the bearings, is there only one small bearing set to replace or are there two sets, one on each side? If there are two, should they both be replaced?
I believe there is only one you need to replace. This was a common issue with the DC24.
Thanks for the guide. $20 for the part and 20 minutes later, I saved myself $400.
You, sir, are awesome.
Bless you for the guide.
No worries! I made this guide to help people do that exact thing.
