Ana içeriğe geç
Dyson DC39 Origin Replacement
Neye ihtiyacın var
    1. Dyson DC39 Origin  Replacement, Bin: adım 1, 3 resimden 1. Dyson DC39 Origin  Replacement, Bin: adım 1, 3 resimden 2. Dyson DC39 Origin  Replacement, Bin: adım 1, 3 resimden 3.
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      FixBot'a Sor
      Yorum Ekle
    1. Dyson DC39 Origin  Replacement, Steering Assembly: adım 2, 3 resimden 1. Dyson DC39 Origin  Replacement, Steering Assembly: adım 2, 3 resimden 2. Dyson DC39 Origin  Replacement, Steering Assembly: adım 2, 3 resimden 3.
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Dyson DC39 Origin  Replacement: adım 3, 3 resimden 1. Dyson DC39 Origin  Replacement: adım 3, 3 resimden 2. Dyson DC39 Origin  Replacement: adım 3, 3 resimden 3.
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      FixBot'a Sor
      Yorum Ekle
    1. Dyson DC39 Origin  Replacement, Inlet Hose: adım 4, 2 resimden 1. Dyson DC39 Origin  Replacement, Inlet Hose: adım 4, 2 resimden 2.
      • Remove the two 17.8 mm Phillips #2 screws located in the top of the inlet hose bracket.
      • Remove the two 13.7 mm Torx 8 screws located at the opposite end of the inlet hose.
      • The Torx 8 screws are located at an odd angle. Be sure the screwdriver is secure to prevent stripping the screws.
      FixBot'a Sor
      Yorum Ekle
    2. Dyson DC39 Origin  Replacement: adım 5, 2 resimden 1. Dyson DC39 Origin  Replacement: adım 5, 2 resimden 2.
      • Pull the inlet hose straight up from the steering assembly.
      • The inlet hose 'snaps' out of its position, so you may have to apply a little extra force while pulling.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Michael Hutcheson
312 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G6
3 Üyeler
51 adet Kılavuz yazıldı
1Rehber Yorum
Really clear instructions - thank you
collette - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 41
Her zaman: 4,831
