Ana içeriğe geç
Dyson DC39 Origin Ball Wheels Replacement
Neye ihtiyacın var
  1. Dyson DC39 Origin Ball Wheels Replacement, Bin: adım 1, 3 resimden 1. Dyson DC39 Origin Ball Wheels Replacement, Bin: adım 1, 3 resimden 2. Dyson DC39 Origin Ball Wheels Replacement, Bin: adım 1, 3 resimden 3.
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: adım 2, 3 resimden 1. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: adım 2, 3 resimden 2. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: adım 2, 3 resimden 3.
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin Ball Wheels Replacement: adım 3, 3 resimden 1. Dyson DC39 Origin Ball Wheels Replacement: adım 3, 3 resimden 2. Dyson DC39 Origin Ball Wheels Replacement: adım 3, 3 resimden 3.
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
  4. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: adım 4, 2 resimden 1. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: adım 4, 2 resimden 2.
    • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
    • There is one screw located at the center of each wheel.
  5. Dyson DC39 Origin Ball Wheels Replacement: adım 5, 3 resimden 1. Dyson DC39 Origin Ball Wheels Replacement: adım 5, 3 resimden 2. Dyson DC39 Origin Ball Wheels Replacement: adım 5, 3 resimden 3.
    • Pull the wheel away from the main body of the device.
    • This may require a lot of force. The plastic wheel may bend slightly.
Sonuç
Michael Hutcheson
297 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 2,301
