Ana içeriğe geç
Dyson DC39 Origin Cyclone Filter Replacement
Neye ihtiyacın var
    1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: adım 1, 3 resimden 1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: adım 1, 3 resimden 2. Dyson DC39 Origin Cyclone Filter Replacement, Bin: adım 1, 3 resimden 3.
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      FixBot'a Sor
      Yorum Ekle
    1. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: adım 2, 3 resimden 1. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: adım 2, 3 resimden 2. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: adım 2, 3 resimden 3.
      • Remove the purple pre-filter by pulling it up and out of the bin.
      FixBot'a Sor
      Yorum Ekle
    1. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: adım 3, 2 resimden 1. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: adım 3, 2 resimden 2.
      • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
      FixBot'a Sor
      Yorum Ekle
    2. Dyson DC39 Origin Cyclone Filter Replacement: adım 4, 1 resimden 1.
      • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
      • The grey button can only be pressed after the bottom section is open.
      FixBot'a Sor
      Yorum Ekle
    3. Dyson DC39 Origin Cyclone Filter Replacement: adım 5, 3 resimden 1. Dyson DC39 Origin Cyclone Filter Replacement: adım 5, 3 resimden 2. Dyson DC39 Origin Cyclone Filter Replacement: adım 5, 3 resimden 3.
      • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
      • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sam Nelson
167 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G6
3 Üyeler
54 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 17
Son 30 gün: 65
Her zaman: 4,096
