Ana içeriğe geç
Dyson DC39 Origin Steering Assembly Replacement
Neye ihtiyacın var
  1. Dyson DC39 Origin Steering Assembly Replacement, Bin: adım 1, 3 resimden 1. Dyson DC39 Origin Steering Assembly Replacement, Bin: adım 1, 3 resimden 2. Dyson DC39 Origin Steering Assembly Replacement, Bin: adım 1, 3 resimden 3.
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: adım 2, 3 resimden 1. Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: adım 2, 3 resimden 2. Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: adım 2, 3 resimden 3.
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin Steering Assembly Replacement: adım 3, 3 resimden 1. Dyson DC39 Origin Steering Assembly Replacement: adım 3, 3 resimden 2. Dyson DC39 Origin Steering Assembly Replacement: adım 3, 3 resimden 3.
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Luke Matusiak
479 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G6
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Thank you, thank you, thank you!
Robin Hill - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 780
