Ana içeriğe geç
Dyson DC56 Battery Replacement
Neye ihtiyacın var
  1. Dyson DC56 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Battery Replacement: adım 2, 1 resimden 1.
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Battery Replacement: adım 3, 1 resimden 1.
    • Separate the device with the purple button.
  4. Dyson DC56 Battery Replacement: adım 4, 1 resimden 1.
    • Take out the filter.
  5. Dyson DC56 Battery Replacement: adım 5, 1 resimden 1.
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Battery Replacement, Battery screw 2: adım 6, 1 resimden 1.
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Battery Replacement: adım 7, 1 resimden 1.
    • Pull the battery pack down and away from the main body and remove it from the device.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Vu Nguyen
189 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G1, Thompson Fall 2017 USF Tampa, Team S10-G1, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G1
4 Üyeler
11 adet Kılavuz yazıldı
9 Yorum
Works for the DC44 animal also. :)
Tina Willman-Hammar - Yanıt
You left out the removal of the screw above the charging port.
Mike - Yanıt
And after unscrewing the 2nd screw, you need very fine tweezers to extract it.
This experience has convinced me never to buy a Dyson product. Their manual gives no info about replacing the battery.
Loohan7 - Yanıt
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Cliff - Yanıt
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
Mark Nicoll - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 97
Her zaman: 9,852
