Ana içeriğe geç
Dyson DC56 Cyclone Replacement
Neye ihtiyacın var
  1. Dyson DC56 Cyclone Replacement, Dust Bin: adım 1, 1 resimden 1.
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
    FixBot'a Sor
    Yorum Ekle
  2. Dyson DC56 Cyclone Replacement: adım 2, 1 resimden 1.
    • Locate the purple button at the top of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Dyson DC56 Cyclone Replacement: adım 3, 1 resimden 1.
    • Separate the device with the purple button.
    FixBot'a Sor
    Yorum Ekle
  4. Dyson DC56 Cyclone Replacement: adım 4, 1 resimden 1.
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
    FixBot'a Sor
    Yorum Ekle
  5. Dyson DC56 Cyclone Replacement: adım 5, 1 resimden 1.
    • Push the red lever to release the dust bin lid.
    FixBot'a Sor
    Yorum Ekle
  6. Dyson DC56 Cyclone Replacement: adım 6, 1 resimden 1.
    • Locate the red lever below the vacuum.
    FixBot'a Sor
    Yorum Ekle
  7. Dyson DC56 Cyclone Replacement: adım 7, 1 resimden 1.
    • Push the red lever, pull the back up and away from the dust bin to separate them.
    FixBot'a Sor
    Yorum Ekle
  8. Dyson DC56 Cyclone Replacement, Cyclone: adım 8, 1 resimden 1.
    • Use a T8-Torque screwdriver to remove the 18mm screw from the back of the Cyclone.
    FixBot'a Sor
    Yorum Ekle
  9. Dyson DC56 Cyclone Replacement: adım 9, 1 resimden 1.
    • Remove the bottom of the cyclone screen by twisting it to the left and pulling down.
    FixBot'a Sor
    Yorum Ekle
  10. Dyson DC56 Cyclone Replacement: adım 10, 1 resimden 1.
    • Remove the rest of the cyclone screen by pulling down.
    FixBot'a Sor
    Yorum Ekle
  11. Dyson DC56 Cyclone Replacement: adım 11, 1 resimden 1.
    • Locate and take out the six 26mm screws with a T-8 Torque screwdriver.
    • Once you have removed the screws you can remove the rest of the Cyclone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Czerkawski
427 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G1, Thompson Fall 2017 USF Tampa, Team S10-G1, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G1
4 Üyeler
11 adet Kılavuz yazıldı
1Rehber Yorum
I can’t remove the cyclone screen. Any tricks to removing?
J M - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 1,304
