Ana içeriğe geç
Dyson DC56 Motor Replacement
Neye ihtiyacın var
  1. Dyson DC56 Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Motor Replacement: adım 2, 1 resimden 1.
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Motor Replacement: adım 3, 1 resimden 1.
    • Separate the device with the purple button.
  4. Dyson DC56 Motor Replacement: adım 4, 1 resimden 1.
    • Take out the filter.
  5. Dyson DC56 Motor Replacement: adım 5, 1 resimden 1.
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Motor Replacement, Battery screw 2: adım 6, 1 resimden 1.
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Motor Replacement: adım 7, 1 resimden 1.
    • Pull the battery pack down and away from the main body and remove it from the device.
  8. Dyson DC56 Motor Replacement, Motor: adım 8, 1 resimden 1.
    • Take out the 10mm screw using a Phillips #1 screwdriver.
  9. Dyson DC56 Motor Replacement: adım 9, 1 resimden 1.
    • Use a spudger to separate the back plate covering the motor.
    • Be careful when trying to remove the motor with a metal spudger. Be sure your battery is removed before trying to fully remove the motor.
  10. Dyson DC56 Motor Replacement: adım 10, 1 resimden 1.
    • Use a flat spudger to loosen and remove the motor out of the vacuum.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Czerkawski
427 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G1, Thompson Fall 2017 USF Tampa, Team S10-G1, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G1
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 2,837
