Ana içeriğe geç
Dyson Pure Cool AM11 Base Replacement
Neye ihtiyacın var
  1. Dyson Pure Cool AM11 Base Replacement, Base: adım 1, 3 resimden 1. Dyson Pure Cool AM11 Base Replacement, Base: adım 1, 3 resimden 2. Dyson Pure Cool AM11 Base Replacement, Base: adım 1, 3 resimden 3.
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Base Replacement: adım 2, 3 resimden 1. Dyson Pure Cool AM11 Base Replacement: adım 2, 3 resimden 2. Dyson Pure Cool AM11 Base Replacement: adım 2, 3 resimden 3.
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Base Replacement: adım 3, 2 resimden 1. Dyson Pure Cool AM11 Base Replacement: adım 3, 2 resimden 2.
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
  4. Dyson Pure Cool AM11 Base Replacement: adım 4, 3 resimden 1. Dyson Pure Cool AM11 Base Replacement: adım 4, 3 resimden 2. Dyson Pure Cool AM11 Base Replacement: adım 4, 3 resimden 3.
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
Bitiş Çizgisi
Gregory Crimmins
109 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 89
