Giriş
This Guide is to help you if you need to get access to the inside of your fan to fix wire the motor or other parts. We will walk you through the steps to safely open it up and put it back together.
Neye ihtiyacın var
With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
Neredeyse bitti!
Bitiş Çizgisi
