Ana içeriğe geç
Dyson Pure Cool AM11 Oscillation Motor Replacement
Neye ihtiyacın var
  1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: adım 1, 3 resimden 1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: adım 1, 3 resimden 2. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: adım 1, 3 resimden 3.
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 2, 3 resimden 1. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 2, 3 resimden 2. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 2, 3 resimden 3.
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 3, 2 resimden 1. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 3, 2 resimden 2.
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
  4. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 4, 3 resimden 1. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 4, 3 resimden 2. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 4, 3 resimden 3.
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
  5. Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: adım 5, 2 resimden 1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: adım 5, 2 resimden 2.
    • Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
  6. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 6, 2 resimden 1. Dyson Pure Cool AM11 Oscillation Motor Replacement: adım 6, 2 resimden 2.
    • (Optionally) Use a jimmy around the edge of the motor to loosen it from its housing.
    • Lift the motor out of its housing.
    • Ensure that you do not grab the motor by the swing arm as you may damage both the motor and surrounding components.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
AidenManchester
252 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G7
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where’d you get the motor
Jon Murch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 229
