Ana içeriğe geç
Dyson Supersonic HD01 Filter Mesh Replacement
Neye ihtiyacın var
  1. Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: adım 1, 2 resimden 1. Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: adım 1, 2 resimden 2.
    • Find the red dot along the top of the filter cover.
    • The red dot will be aligned with the white dot at the bottom of the hair dryer's handle.
    • Twist the filter cover counter-clockwise until the red dot is shifted to align with the white empty circle on the dryer handle.
    FixBot'a Sor
  2. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: adım 2, 2 resimden 1. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: adım 2, 2 resimden 2.
    • Remove the filter cover by sliding it off of the handle.
    FixBot'a Sor
  3. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the retaining screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    T6 Torx Screwdriver
    $9.99
    • Remove the two retaining screws at the base of the handle using a T6 Screwdriver.
    FixBot'a Sor
  4. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: adım 4, 3 resimden 1. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: adım 4, 3 resimden 2. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: adım 4, 3 resimden 3.
    • Seperate the filter mesh at the plastic seam by pulling it apart.
    • Remove the filter mesh by sliding it off of the handle.
    FixBot'a Sor
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ezra Linza
199 İtibar
1 Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-5, McMurrin Fall 2022 Utah Tech University, Team 1-5, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G5
3 Üyeler
9 adet Kılavuz yazıldı
5Kılavuz Yorumları
This guide is misleading and obviously trolling. The cable is attached to two ton of power converter bricks there's no way this thing will "slide off" the cable. lol.
gcb - Yanıt Paylaş
The REAL procedure is so complicated, the only REAL tutorial/guide i have found prefers to disassemble the entire device instead of dealing with the power bricks. https://www.youtube.com/watch?v=2XnUlUBZ...
gcb - Yanıt Paylaş
slide right off. lol. https://www.youtube.com/watch?v=fsiXJndd... hope you have a saw and several pry tools.
gcb - Yanıt Paylaş
updated the guide but i'm not sure how to add steps from another guide (on replacing the motor) up to step 6 only...
gcb - Yanıt Paylaş
Yep this works. The fiddly bit is getting the filter back in but it’s doable with a little patience and persistence. I didn’t replace the filter but did take it out to clean it properly as this small mesh cannot be cleaned properly from the outside.
DavidHK - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 63
Son 30 gün: 316
Her zaman: 11,079
