Ana içeriğe geç
Dyson V8 Absolute Battery Replacement
Neye ihtiyacın var
    1. Dyson V8 Absolute Battery Replacement, Battery: adım 1, 2 resimden 1. Dyson V8 Absolute Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Detach wand from device.
      • Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
      • Screw Head Type: Phillips #2
      • Screw Length: 170mm
      FixBot'a Sor
      Yorum Ekle
    2. Dyson V8 Absolute Battery Replacement: adım 2, 3 resimden 1. Dyson V8 Absolute Battery Replacement: adım 2, 3 resimden 2. Dyson V8 Absolute Battery Replacement: adım 2, 3 resimden 3.
      • Turn device completely over to view battery pack.
      • Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
      FixBot'a Sor
      Yorum Ekle
    3. Dyson V8 Absolute Battery Replacement: adım 3, 3 resimden 1. Dyson V8 Absolute Battery Replacement: adım 3, 3 resimden 2. Dyson V8 Absolute Battery Replacement: adım 3, 3 resimden 3.
      • Pull the battery pack down and away from the device.
      • Battery pack may fall out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
61 farklı kişi bu kılavuzu tamamladı.
Jasvir Dosanjh
1.959 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G5
4 Üyeler
21 adet Kılavuz yazıldı
18Kılavuz Yorumları
Great instructions!!
akcosta60 - Yanıt Paylaş
I have replaced the battery and I still got a flashing red light, any ideas
georgewaterson - Yanıt Paylaş
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - Yanıt Paylaş
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
anthony richards - Yanıt Paylaş
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
Trunker Trubshaw - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 99
Son 7 gün: 477
Son 30 gün: 1,957
Her zaman: 216,739
