Ana içeriğe geç
E-Cigarette Vaporizer Coil Replacement
Neye ihtiyacın var
  1. E-Cigarette Vaporizer Coil Replacement, Coil: adım 1, 2 resimden 1. E-Cigarette Vaporizer Coil Replacement, Coil: adım 1, 2 resimden 2.
    • Pull up to remove the top cap from the IPV Mini II.
    • The unit may have hot surfaces.
    • Allow components to cool before starting.
  2. E-Cigarette Vaporizer Coil Replacement: adım 2, 1 resimden 1.
    • Using a Phillips head screwdriver, turn counter clockwise to loosen the positive and negative screws.
    • Be sure that the IPV Mini II is powered off before proceeding.
  3. E-Cigarette Vaporizer Coil Replacement: adım 3, 1 resimden 1.
    • Gently remove the burnt coil from the positive and negative screws.
  4. E-Cigarette Vaporizer Coil Replacement: adım 4, 1 resimden 1.
    • Place the new coil into the holes underneath the positive and negative screws.
  5. E-Cigarette Vaporizer Coil Replacement: adım 5, 1 resimden 1.
    • Using a Phillips screwdriver, gently turn clockwise to tighten down the positive and negative screws onto the coil.
  6. E-Cigarette Vaporizer Coil Replacement: adım 6, 2 resimden 1. E-Cigarette Vaporizer Coil Replacement: adım 6, 2 resimden 2.
    • Replace the top cap onto the IPV Mini II.
Sonuç
To reverse the process, simply follow the instructions in reverse.
For more information visit https://bevapehappy.com/
12 farklı kişi bu kılavuzu tamamladı.
rzgraves
624 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 3-4, Rauch SU 2015 Texas Tech, Team 3-4, Rauch SU 2015 üyesi
TTU-RAUCH-SU15S3G4
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 5,214
