Ana içeriğe geç
EBK340 Powerhead Replacement
Neye ihtiyacın var
  1. EBK340  Powerhead  Replacement, Remove Outer Cover: adım 1, 1 resimden 1.
    • Position the device so brushes are upwards and visible
    • Unscrew the 6 outer screws. 2 on the edge of the brush crevice, and 4 nearer to the wheels.
    • Turn over the device.
    • Pull the cover off gently.
    FixBot'a Sor
    Yorum Ekle
  2. EBK340  Powerhead  Replacement, Remove Inner Cover: adım 2, 1 resimden 1.
    • Unscrew the 2 screws indicated, one visible, the other within a deep hole
    • Gently pull off the cover. Careful not to torque the plastic teeth shown in orange.
    FixBot'a Sor
    Yorum Ekle
  3. EBK340  Powerhead  Replacement, Replace Neck Joint: adım 3, 2 resimden 1. EBK340  Powerhead  Replacement, Replace Neck Joint: adım 3, 2 resimden 2.
    • Gently lift the two LED lights upwards and away for the moment.
    • Gently lift out the defective neck joint.
    • Slide in the replacement joint.
    • Replace the lights into the molded corners that hold their board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
FolsomMaids Office
167 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 289
