Giriş
Follow this guide to remove and replace the power cord on an EDCO Floor Stripper TS8 .75L (2017).
Neye ihtiyacın var
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a Phillips screwdriver to remove the screw from the center of the red on/off knob.
Remove the black plastic cap from the center of the switch assembly.
Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
Use a socket to remove the four 11/32 inch nuts from the on/off switch bracket.
Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
Use a flathead screwdriver to loosen the two screws on the right side of the switch assembly securing the black and white wires from the power cord.
Use two adjustable wrenches to unscrew the strain relief fitting by turning the locknut counterclockwise relative to the fitting.
1-1/16 inch lock nut
15/16 inch strain relief fitting
2 farklı kişi bu kılavuzu tamamladı.
