Ana içeriğe geç
EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement
Neye ihtiyacın var
  1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Chock the wheels: adım 1, 2 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Chock the wheels: adım 1, 2 resimden 2.
    • Before you begin, ensure the machine is powered down and cool to the touch.
    • Chock the wheels to prevent the machine from moving while you are working on it.
  2. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Turn off the ignition switches: adım 2, 3 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Turn off the ignition switches: adım 2, 3 resimden 2. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Turn off the ignition switches: adım 2, 3 resimden 3.
    • Flip the ignition switches on the motor and the handle bar into their "OFF" positions.
  3. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Close the fuel valve: adım 3, 2 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Close the fuel valve: adım 3, 2 resimden 2.
    • Flip the fuel cutoff valve switch into the off position.
  4. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Disconnect the spark plug: adım 4, 2 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Disconnect the spark plug: adım 4, 2 resimden 2.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the air cleaner cover: adım 5, 3 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the air cleaner cover: adım 5, 3 resimden 2. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the air cleaner cover: adım 5, 3 resimden 3.
    • Unscrew the wing nut on top of the air cleaner cover.
  6. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 6, 2 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 6, 2 resimden 2.
    • Remove the air cleaner cover.
    • This will make it easier to reach the throttle cable holder with a screwdriver.
  7. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle cable: adım 7, 2 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle cable: adım 7, 2 resimden 2.
    • Use a short Phillips screwdriver to remove the screw securing the throttle cable holder.
  8. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 8, 3 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 8, 3 resimden 2. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 8, 3 resimden 3.
    • Lift the throttle cable up to a vertical position and pull it straight up to remove it from the throttle control lever.
  9. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle control assembly: adım 9, 2 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement, Remove the throttle control assembly: adım 9, 2 resimden 2.
    • Grip the black throttle control knob and pull it straight up and off of the control lever to remove it.
  10. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 10, 1 resimden 1.
    • Use a 7/16 inch socket with a 3/8 inch wrench to remove the two bolts and accompanying nuts securing the throttle control assembly from the handlebar.
  11. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 11, 2 resimden 1. EDCO PRO KL-18 Concrete Saw Throttle Cable Assembly Replacement: adım 11, 2 resimden 2.
    • Remove the throttle control assembly.
Sonuç
Sam Omiotek
68.080 İtibar
288 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 241
