Giriş
The buttons on these speakers can fail. If it is the main power button, it will prevent the speaker switching on completely.
Neye ihtiyacın var
The buttons on these speakers can fail due to corrosion or repeated pressing. They are easy to replace.
You can cut out the old switch using flush cutters or a rotary tool, be careful not to rip the solder pads of the circuit board.
Alternatively, use a hot air gun. You can use low-melting solder to make removal easier.
Sonuç
Reassembly is very simple, you can stick the silicone in case and push the cap back on.
