Giriş
This guide is for the replacement of the GPU fan on the video card. Replacing the other fan would be the same steps, just with the other fan assembly.
Neye ihtiyacın var
If you have any dust caps over the HDMI or Display Port connections, remove them
Remove the 3 screws using a Phillips #1 Screwdriver (Red)
Remove the 2 Standoffs using a 5mm socket
Gently slide the plate out from between the back cover and the circuit board. It should come out without much force.
If it doesn't want to budge, check that the right screw was removed from the top of the video card.
Using the 1.5mm Hex, remove the 4 screws (one on each corner) to release the shroud
Note: there is 4 screws on each corner plate, the other 3 screws do not need to be removed.
The shoud should be able to be lifted free easily, on the wiring harness for the lights.
The connector for the harness is on the inside end end, nearest the power connectors.
The connector can be disconnected to completely seperate the shroud, or left connected if just needing access to the fans.
Using the #1 Phillips Screwdriver, reach between the fins to unscrew the 3 screws holding the fan to the heatsink.
The wiring harness goes under the Blue clip and pulling the wire down will alow it to come free.
The Red box is where the connector is located on the circuit board.
Use the Tweezers to gently disconnect the connector.
Installing the new fan, I found it easier to connect the wiring first, then the fan itself
Connect the connector (the keying points away from you)
Seat the cable under the metal clip
Screw in the 3 screws for the fan
Loosely screw in all 3 screw before screwing them down tight.
Careful to not damage the fan blade, as that would cause premature wear and excess noise.
Bir başkası bu kılavuzu tamamladı.
