Ana içeriğe geç
EVGA x17 Scroll Wheel Replacement
Neye ihtiyacın var
    1. EVGA x17 Scroll Wheel Replacement, Scroll Wheel: adım 1, 1 resimden 1.
      • Remove the mouse skates to reveal 5 screws.
      FixBot'a Sor
      Yorum Ekle
    2. EVGA x17 Scroll Wheel Replacement: adım 2, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    3. EVGA x17 Scroll Wheel Replacement: adım 3, 1 resimden 1.
      • Remove the weight chamber cover.
      FixBot'a Sor
      Yorum Ekle
    4. EVGA x17 Scroll Wheel Replacement: adım 4, 1 resimden 1.
      • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
      FixBot'a Sor
      Yorum Ekle
    5. EVGA x17 Scroll Wheel Replacement: adım 5, 2 resimden 1. EVGA x17 Scroll Wheel Replacement: adım 5, 2 resimden 2.
      • Remove the 13 screws on the interior.
      • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
      FixBot'a Sor
      Yorum Ekle
    6. EVGA x17 Scroll Wheel Replacement: adım 6, 1 resimden 1.
      • Carefully slide middle section out.
      FixBot'a Sor
      Yorum Ekle
      • Remove smaller sized cross head screws from piece labeled AZAC001-A V1.0.
      FixBot'a Sor
      Yorum Ekle
    7. EVGA x17 Scroll Wheel Replacement: adım 8, 1 resimden 1.
      • Pull the transistor from the side of the mouse wheel.
      FixBot'a Sor
      Yorum Ekle
    8. EVGA x17 Scroll Wheel Replacement: adım 9, 1 resimden 1.
      • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
      • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
      FixBot'a Sor
      Yorum Ekle
    9. EVGA x17 Scroll Wheel Replacement: adım 10, 2 resimden 1. EVGA x17 Scroll Wheel Replacement: adım 10, 2 resimden 2.
      • Remove scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue).
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sydney Puett
604 İtibar
3 adet Kılavuz yazıldı
2Kılavuz Yorumları
Is there a wheel that can be purchased that will fit or can be modified to fit for the replacement.
Ronald Winfrey - Yanıt Paylaş
The only solution I've found so far is to 3D print the wheel. Now, my X17 mouse is working.
Carlos Pavon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 63
Her zaman: 2,885
